[Gdal-dev] GDAL 1.2.2 Released
Eduardo Patto Kanegae
lists at webmapit.com.br
Thu Sep 16 18:56:01 EDT 2004
# Hi Frank,
On Thu, 16 Sep 2004 16:54:35 -0400, Frank Warmerdam <warmerdam at pobox.com> escreveu:
> De: Frank Warmerdam <warmerdam at pobox.com>
> Data: Thu, 16 Sep 2004 16:54:35 -0400
> Para: gdal-dev <gdal-dev at remotesensing.org>, FreeGIS <freegis-list at intevation.de>
> Assunto: [Gdal-dev] GDAL 1.2.2 Released
> Folks,
> GDAL 1.2.2 - Overview of Changes
> OGR 1.2.2 - Overview of Changes
> SQLite Driver:
> - New read/write driver implemented for SQLite databases.
# it means will be possible to store POINTS tables on databases such as MySQL, Informix, MSSQL, DB2, etc a then display these data using tools like MapServer ? or it will also possible to store complex geometries(line/poly's)?
> CSV Driver:
> - New read/write driver implemented for comma seperated value files.
# I never used this OGR option... what is it for? it is possible to load a CVS like:
POINTID;NAME;X;Y
0;A;210.5;53
1;B;268;9.68
... and so on...
> GEOS:
> - Integration a series of methods utilizing GEOS when available. Note
> that Intersect() is still just an envelope comparison.
# cool... means OGR can make topological tests?
> OGRSpatialReference:
> - Fixed Swiss Oblique Mercator support.
> A new OpenEV_FW 1.8.2 synced with GDAL 1.2.2 should following within a few
> hours.
> Best regards,
# best.
http://www.webmapit.com.br
UIN: 303747254
Treinamento em UMN MapServer - http://www.webmapit.com.br/ptbr/?menuoption=mapserver
Fórum MapServer Brasil - http://mapserver.cttmar.univali.br/forum
***Fim da Mensagem / End of Message ***
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
