[Gdal-dev] Python modules fail to compile on MAC OS X
Zak James
zak-ms at hoppsan.org
Wed Sep 22 20:29:03 EDT 2004
Jeroen,
I answered this question on the list a few months ago. You may find
more details in the archive, but I'm including what I wrote then.
I've since determined that for install to proceed, you need to set a
pymod install directory in GDALmake.opt:
INST_PYMOD = ${prefix}/lib/python2.3/site-packages/
and make some modifications to the pymod makefile because it thinks the
bundle extension will be .dylib instead of .so
zak
> Date: July 25, 2004 12:05:55 PM EDT
> Cc: gdal-dev at remotesensing.org
> Subject: Re: [Gdal-dev] Built gdal with python support - error
> I recently built gdal's python support on OS X 10.3 (with the OS
> supplied Python 2.3) by relying on the apple compiler's support for
> frameworks.
> After you configure --without-python, edit the python section of
> GDALMake.opt like so:
> PYTHON_INCLUDES =
> -I/System/Library/Frameworks/Python.framework/Versions/2.3/include/
> python2.3
> PYTHON_LIBS = -framework Python
> PYTHON_CFLAGS =
> PYTHON = yes
> and run make. The only other problem seems to be that the shared
> library is not created as a bundle so after everything is built, you
> need to build the python module using something like:
> g++ -bundle -flat_namespace gdal_wrap.o numpydataset.o gdalnumeric.o
> -L.. -lgdal -framework Python -ljpeg -lpng -lz -ldl -o _gdalmodule.so
> If you run otool -L on the .so file, you can verify that it is using
> the appropriate libraries.
> zak
> Zak James
> Applications and Software Development
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
Zak James
On Sep 22, 2004, at 3:51 PM, Ticheler, Jeroen (SDRN) wrote:
> I have a problem compiling the Python modules of GDAL on MAC OS X. I
> have
> seen this problem has been discussed previously (around December
> 2003), but I
> have found no solution yet. Does anyone have a solution?
> Thanks,
> Jeroen
> Error while compiling:
> (cd pymod; make)
> GNUmakefile:35: warning: overriding commands for target
> `_gdalmodule.la'
> GNUmakefile:29: warning: ignoring old commands for target
> `_gdalmodule.la'
> /bin/sh ../libtool --mode=link g++ gdal_wrap.lo numpydataset.lo
> gdalnumeric.lo
> /System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3
> ../libgdal.la -o _gdalmodule.la \
> -rpath
> python2.3/site-p
> ackages \
> -no-undefined \
> -avoid-version \
> -module
> g++ -Wl,-bind_at_load -o .libs/_gdalmodule.so -bundle
> .libs/gdal_wrap.o
> .libs/numpydataset.o .libs/gdalnumeric.o -L/usr/local/lib
> ../.libs/libgdal.dylib
> ld: Undefined symbols:
> _PyArg_Parse
> _PyArg_ParseTuple
> _PyDict_New
> _PyDict_Next
> _PyDict_SetItem
> _PyDict_Type
> _PyErr_Clear
> _PyErr_SetString
> _PyEval_CallObjectWithKeywords
> _PyExc_MemoryError
> _PyExc_NameError
> _PyExc_TypeError
> _PyExc_ValueError
> _PyFloat_AsDouble
> _PyFloat_FromDouble
> _PyInt_AsLong
> _PyInt_FromLong
> _PyInt_Type
> _PyList_New
> _PyList_SetItem
> _PyList_Size
> _PyList_Type
> _PyModule_GetDict
> _PyObject_AsWriteBuffer
> _PyString_AsString
> _PyString_FromString
> _PyString_FromStringAndSize
> _PyString_Type
> _PyTuple_Size
> _PyTuple_Type
> _PyType_IsSubtype
> _PyType_Type
> _Py_BuildValue
> _Py_InitModule4
> __Py_NoneStruct
> make[1]: *** [_gdalmodule.la] Error 1
> make: *** [py-module] Error 2
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
