[Gdal-dev] netcdf reading problems
Norman Vine nhv at cape.com
Thu Sep 30 09:55:25 EDT 2004
Frank Warmerdam writes:
> Tim Sutton wrote:
> > Hi
> > I am trying to read netcdf data with gdal so that I can convert it to ascii
> > format, and to be able to view it in QGIS. I found that gdal wont read
> > any .nc files I give it. The data I am trying to read is multiband (e.g.
> > http://linux-gis.co.uk/climate_sample.nc), but even a simple single band
> > layer (http://linux-gis.co.uk/simple.nc) wont read. Iget error message like
> > this from gdal:
> > aps02ts at linux:/tmp/netcdf_tests> gdalinfo simple.nc
> > ERROR 4: `simple.nc' not recognised as a supported file format.
> Tim,
> When I wrote the netcdf driver I was primarily interested in exchanging data
> with GMT which uses a very specific organization of the data.  The GDAL
> netCDF driver ignores datasets (even netCDF files) that don't match those
> assumptions.
> Your dataset does not appear to have been generated by GMT.
> I do hope to rewrite this driver someday to adhere to the more general
> COORDS definitions for grid data but this is a reasonably substantial
> job and not anywhere near the top of my priority pile.
Tim
If you use Python you will should find a combination of GDAL's Python
Interface and Konrad Hinsen's Scientific Python extension module useful,
as Scientific Python contains a generic NetCDF interface.
http://dirac.cnrs-orleans.fr/ScientificPython/
HTH
Norman
