[Gdal-dev] incorporating changes in hfa dataset into GDAL
Stephane Routelous
route at cae.com
Fri Apr 1 13:41:49 EST 2005
Ok, thanks,
I will wait till is up and do it in bugzilla
Do I attach the whole file (the changes are done in the 1.2.5 version), or
just the part of the code I added ?
Stephane
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
Sent: Friday, April 01, 2005 1:39 PM
To: Stephane Routelous
Cc: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] incorporating changes in hfa dataset into GDAL
On Apr 1, 2005 1:29 PM, Stephane Routelous <route at cae.com> wrote:
> Hi,
> I've made some changes to the hfadataset.
> what are the procedures to incorporate those changes in gdal ?
> Do I have to send the modified files ? the diff ?
> to which mail address ?
STephane,
I would encourage you to submit them via the GDAL bugzilla. Just
now it is down, but it will hopefully be availble within a few hours.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
