[Gdal-dev] More problems compiling under VS.NET 2003
Thom DeCarlo
t.r.decarlo at larc.nasa.gov
Tue Apr 5 17:43:36 EDT 2005
Thanks Frank. That fixed it.
Thom
Thom DeCarlo
I work until beer o'clock
- Steven King
> -----Original Message-----
> From: Frank Warmerdam
> Sent: Tuesday, April 05, 2005 5:35 PM
> To: Thom DeCarlo
> Cc: gdal-dev
> Subject: Re: [Gdal-dev] More problems compiling under VS.NET 2003
> Thom,
> Try adding STDCALL=YES in your nmake.opt and then do a full
> clean build. I am in the midst of lots of changes related to
> making some C entry points have STDCALL conventions but
> I hadn't updated the nmake.opt with the right defaults. The
> changes is in CVS now or you can manually update yours.
> Best regards,
