[Gdal-dev] Link errors with Ilwis in MS dotnet SDK
Howard Butler
hobu at iastate.edu
Wed Apr 13 23:11:55 EDT 2005
Jacob,
You can disable the ilwis driver by editing the makefile.vc in the
frmts directory and removing the -DFRMT_ilwis variable in the
EXTRAFLAGS line.
Howard
At 1:04 PM +1000 4/14/05, Delfos, Jacob wrote:
>Hi List,
>When trying to compile using the CVS version of April 13, I get some
>errors about "ilwiscoordinatesystem.obj". I have tried to remove it
>from the makefile.vc, which results in it compiling at least to the
>stage of the DLL (which is all I need).
>Unfortunately, the DLL doesn't quite seem to work, because
>php_mapscript_44 won't load. When using "depends.exe", I get this
>error:
>Error: At least one module has an unresolved import due to a missing
>export function in an implicitly dependent module.
>It shows gdal12.dll in red, although running "depends" on gdal12.dll
>itself gives no errors.
>Can anyone tell me whether "Ilwis" is essential, or what else the
>problem could be? Using the same platform, I previously compiled a
>working DLL (gdal125).
>The link errors I get if I keep Ilwis included are:
>msvcprt.lib(msvcp71imp.obj) : error LNK2005: "class
>std::basic_istream<char,struct std::char_traits<char> > & __cdecl st
>d::operator>><char,struct std::char_traits<char>,class
>std::allocator<char> >(class std::basic_istream<char,struct std::
>char_traits<char> > &,class std::basic_string<char,struct
>std::char_traits<char>,class std::allocator<char> > &)" (??$?5
>DU?$char_traits at D@std@@V?$allocator at D@1@@std@@YAAAV?$basic_istream at DU?$char_traits at D@std@@@0 at AAV10@AAV?$basic_string at DU?
>$char_traits at D@std@@V?$allocator at D@2@@0@@Z) already defined in
>msvcprt.lib(msvcp71imp.obj) : warning LNK4006: "class
>std::basic_istream<unsigned short,struct std::char_traits<unsigned
> short> > & __cdecl std::getline<unsigned short,struct
>std::char_traits<unsigned short>,class std::allocator<unsigned sh
>ort> >(class std::basic_istream<unsigned short,struct
>std::char_traits<unsigned short> > &,class std::basic_string<unsig
>ned short,struct std::char_traits<unsigned short>,class
>std::allocator<unsigned short> > &,unsigned short)" (??$getline@
>GU?$char_traits at G@std@@V?$allocator at G@2@@std@@YAAAV?$basic_istream at GU?$char_traits at G@std@@@0 at AAV10@AAV?$basic_string at GU?
>$char_traits at G@std@@V?$allocator at G@2@@0 at G@Z) already defined in
>ilwiscoordinatesystem.obj; second definition ignored
> Creating library gdal_i.lib and object gdal_i.exp
>MSVCRT.lib(cinitexe.obj) : warning LNK4098: defaultlib 'libc.lib'
>conflicts with use of other libs; use /NODEFAULTLIB:li
>brary
>gdal12.dll : fatal error LNK1169: one or more multiply defined symbols found
>NMAKE : fatal error U1077: 'link' : return code '0x491'
>Regards,
>Jacob
>JACOB DELFOS
>SPATIAL INFORMATION ANALYST
>Maunsell Australia Pty Ltd
>629 Newcastle Street, WA 6007
>PO Box 81, WA 6902
>Leederville
>Western Australia
>ABN 20 093 846 925
>Tel + 61 8 9281 6185
>Fax + 61 8 9281 6297
>jacob.delfos at maunsell.com
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at xserve.flids.com
>http://xserve.flids.com/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050413/d6f5d41c/attachment.html
