[Gdal-dev] Stererographic dosen't work
Sam Gurt skyman302 at gmail.com
Fri Apr 22 14:01:02 EDT 2005
When trying to project a grid in latlon to stereographic I get a grid
with values of all 0. I've used the Proj 4 decleration of sterographic
and latlon for both input and output. Additionally I've tried the EPSG
Code for latlon but still no go. Interestingly enough when I open the
reprojected image in ENVI the UL and other coordinates are 40 degrees
away from what I specified in the proj 4 decleration. Any of you know
what might be wrong?
