[Gdal-dev] Stererographic dosen't work
Frank Warmerdam
fwarmerdam at gmail.com
Fri Apr 22 14:05:37 EDT 2005
On 4/22/05, Sam Gurt <skyman302 at gmail.com> wrote:
> When trying to project a grid in latlon to stereographic I get a grid
> with values of all 0. I've used the Proj 4 decleration of sterographic
> and latlon for both input and output. Additionally I've tried the EPSG
> Code for latlon but still no go. Interestingly enough when I open the
> reprojected image in ENVI the UL and other coordinates are 40 degrees
> away from what I specified in the proj 4 decleration. Any of you know
> what might be wrong?
Sam,
Could you give a specific example of what you are doing? If the
underlying stereographic support in PROJ.4 seems to be broken it
might be best to take the issue to the proj mailing list.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
