[Gdal-dev] GDAL CVS access
Peng Gao
pgao at esri.com
Mon Apr 25 10:56:03 EDT 2005
Now I am getting:
CVSROOT: :pserver:cvsanon at cvs.maptools.org:/cvs/maptools/cvsroot (password
authentication)
TCL is *not* available, shell is disabled
cvs login
(Logging in to cvsanon at cvs.maptools.org)
cvs [login aborted]: connect to cvs.maptools.org:2401 failed: Connection
timed out
*****CVS exited normally with code 1*****
> -----Original Message-----
> From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
> Sent: Monday, April 25, 2005 7:17 AM
> To: Peng Gao
> Cc: gdal-dev at xserve.flids.com
> Subject: Re: [Gdal-dev] GDAL CVS access
> On 4/25/05, Peng Gao <pgao at esri.com> wrote:
> > I can't login:
> > cvs login
> > cvs login: authorization failed: server cvs.maptools.org rejected access
> to
> > /cvs/maptools/cvsroot for user cvsanon
> > I am using WinCvs. I tried password 'enter' and '*enter*' and both
> > didn't work. What did I miss?
> Peng,
> The password is blank I believe. Where it says enter, it means for you
> to just hit the enter button on the keyword. If it still doesn't work
> let
> me know and I will dig into it further.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
