[Gdal-dev] JPEG Tiling?
Frank Warmerdam
fwarmerdam at gmail.com
Fri Apr 29 11:43:03 EDT 2005
On 4/29/05, Justin Thomas <justin.w.thomas at gmail.com> wrote:
> I'm fairly new to the geospatial imagery world, so please forgive me
> if this question is totally in left field. I have made a few test
> programs using GDAL and OGR and so far I have been very pleased with
> how easy it was to do fairly complex tasks.
> I read the JPEG driver documentation, but I could not see how to load
> a set of tiled JPG and JGW files so that I can use GDAL to provide a
> window of pixels for the combined area.
> Is there is a simple workaround or could somone please point me to a
> website with a discussion on the limitations on the different formats?
Justin,
Are you wanting to be able to treat a bunch of individual JPEG
files as single virtual GDALDataset? There is no built-in support
for doing that; however, there are a few approaches.
The most obvious is to create a .vrt (virtual) dataset referencing
all the individual tiles. the .vrt file is an XML file that can list
a bunch of other GDAL supported files and listing where they fit
into a virtual file. This is described at:
http://www.gdal.org/gdal_vrttut.html
There is also a script, gdal_merge.py, that can be used to quickly
build a mosaic from a set of georeferenced files. So you could create
a real mosaic from a bunch of jpegfiles with world files using it.
I would be sort of nice to have a gdal_merge.py variation that
just created a virtual file representing essentially the same result
but without copying data; however, I have not built such a utility.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
