[Gdal-dev] Writing an ENVI file.
Frank Warmerdam
fwarmerdam at gmail.com
Fri Aug 5 13:43:10 EDT 2005
On 8/5/05, Ken Sewell <sewell at dramail.com> wrote:
> A co-worker is trying to use gdalwarp to warp an ENVI file into a new
> projection. It seems to work, but when we examine the header file it
> seems to have lost all geotransform and coordinate system info. From
> searching the mailing list archives, I found that writing to envi is not
> complete, but should at least output the coord/geo information. Is there
> a gotcha we need to know about?
Ken,
It looks like Lichun Wang (ITC) did a significant overhaul of the
header writing for ENVI format very shortly after 1.2.6 release. Are
you using 1.2.6 or GDAL CVS? I would encourage you to try a
nightly snapshot if you are currently using 1.2.6.
Looking at the code, it seems it should always write out the
geotransform information as a mapinfo line, even if the coordinate
system is not known. What does the generated header file look like?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
