[Gdal-dev] Writing an ENVI file.
Shoaib Burq (VPAC)
sab at isis.vpac.org
Fri Aug 5 12:37:12 EDT 2005
I seem to recall running into similar issues while converting ESRI Binary
Grids to ENVI format.
Ended up writing a small GDAL program that read the ESRI Grid's Coordinate
system and projection info and spat it out in the ENVI header format
(mapinfo={...})
But I was under the impression is was due to the partial support for
Binary Grids.
What do you get if you run gdalinfo on the file?
Shoaib Burq
VPAC - Geospatial Applications Developer
Building 91, 110 Victoria Street,
Carlton South, Vic 3053, Australia
On Fri, 5 Aug 2005, Ken Sewell wrote:
> A co-worker is trying to use gdalwarp to warp an ENVI file into a new
> projection. It seems to work, but when we examine the header file it
> seems to have lost all geotransform and coordinate system info. From
> searching the mailing list archives, I found that writing to envi is not
> complete, but should at least output the coord/geo information. Is there
> a gotcha we need to know about?
> Ken Sewell Defense Research Associates
> Project Engineer 3915 Germany Lane, Suite 102
> 937-656-4899 x3004 Beavercreek, Ohio 45431-1608
> sewell at dramail.com
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
