[Gdal-dev] mmintrin.h for V
Richard Greenwood richard.greenwood at gmail.com
Sun Aug 14 22:35:19 EDT 2005
Hi Bart and venerable list,
Thanks, I was not familiar with the Windows Platform SDK and I did not
have it installed. After installing it, I now get:
   Cannot open include file: 'NCSJP2File.h'
And I am again suspicious that it might be related to my ECW SDK
version. I am rather a noob at building, so my apologies if I am
overlooking the obvious.
Thanks,
Rich
On 8/14/05, Bart van den Eijnden <bartvde at xs4all.nl> wrote:
> Hi Rich,
> you need to have the Windows Platform SDK installed. Do you have that?
> Best regards,
> Bart
> On Sun, 14 Aug 2005 16:43:25 +0200, Richard Greenwood
> <richard.greenwood at gmail.com> wrote:
> > In trying to build Gdal with ECW support under VC 6.0. It fails at
> > ecwdataset.cpp with mmintrin.h and xmmintrin.h not found.
> > It looks like those header files contain only type definitions and
> > macros, so I tried copying them from mingw, but then I get the error:
> >    "MMX instruction set not enabled"
> > I am using ECW SDK 3.1RC2, might that be my problem?
> > Rich
Richard Greenwood
www.greenwoodmap.com
