[Gdal-dev] mmintrin.h for V
Richard Greenwood richard.greenwood at gmail.com
Sun Aug 14 23:27:35 EDT 2005
Got it! For the record:
1. Download and install Windows Platform SDK as discussed below.
(Thanks Bart!)
2. Download and unpack NCSSource_3-1_RC2.zip from ermapper.com and add:
  INC = ..... -IF:\projects\ECW_SDK_3.1RC2\Source\include
as noted by Brent Fraser in message:
  http://lists.maptools.org/pipermail/gdal-dev/2005-April/005506.html
(Thanks Brent!)
Best regards,
Rich
Richard Greenwood <richard.greenwood <at> gmail.com> writes:
> Hi Bart and venerable list,
> Thanks, I was not familiar with the Windows Platform SDK and I did not
> have it installed. After installing it, I now get:
>    Cannot open include file: 'NCSJP2File.h'
> And I am again suspicious that it might be related to my ECW SDK
> version. I am rather a noob at building, so my apologies if I am
> overlooking the obvious.
> Thanks,
> Rich
> On 8/14/05, Bart van den Eijnden <bartvde <at> xs4all.nl> wrote:
> > Hi Rich,
> > you need to have the Windows Platform SDK installed. Do you have that?
> > Best regards,
> > Bart
> > On Sun, 14 Aug 2005 16:43:25 +0200, Richard Greenwood
> > <richard.greenwood <at> gmail.com> wrote:
> > > In trying to build Gdal with ECW support under VC 6.0. It fails at
> > > ecwdataset.cpp with mmintrin.h and xmmintrin.h not found.
> > > It looks like those header files contain only type definitions and
> > > macros, so I tried copying them from mingw, but then I get the error:
> > >    "MMX instruction set not enabled"
> > > I am using ECW SDK 3.1RC2, might that be my problem?
> > > Rich
Richard Greenwood
www.greenwoodmap.com
