[Gdal-dev] AttributeError: Driver instance has no attribute 'has_key'
Paulick Consult stefan.paulick at urbeli.com
Mon Aug 15 10:39:21 EDT 2005
Hello list,
when working trough http://www.gdal.org/gdal_tutorial.html,
this error came up:
if metadata.has_key(gdal.DCAP_CREATE) \
Did I miss something or is has_key not longer available?
code was:
import gdal
from gdalconst import *
filename= 'c:\data\ueb.bild'
dataset = gdal.Open( filename, GA_ReadOnly )
if dataset is None:
   print "bild nicht angelegt:",filename
   format = "GTiff"
   metadata = gdal.GetDriverByName( format )
      and metadata[gdal.DCAP_CREATE] == 'YES':
       print 'Driver %s supports Create() method.' % format
   if metadata.has_key(gdal.DCAP_CREATECOPY) \
      and metadata[gdal.DCAP_CREATECOPY] == 'YES':
       print 'Driver %s supports CreateCopy() method.' % format
Mit freundlichen Grüßen / With kindest regards
Stefan Paulick
http://www.urbeli.com
mailto://stefan.paulick@urbeli.com
