[Gdal-dev] GDAL 1.3.0, compile errors
Armin Burger armin.burger at gmx.net
Mon Aug 22 13:11:22 EDT 2005
Frank Warmerdam wrote:
>On 8/19/05, Armin Burger <armin.burger at gmx.net> wrote:
>>Hello,
>>I tried to compile GDAL 1.3.0 on Debian Linux using the configuration
>>./configure --with-pg=/usr/local/pgsql/bin/pg_config
>>--with-geos=yes      --with-xerces --with-xerces-lib="-L/usr/local/lib
>>-lxerces-c1_7_0 -lpthread"  --with-xerces-inc=/usr/local/include/xercesc
>>--with-ecw=/home/install/mapserver/ecwsdk-3.1.25Jan05-linux/ --with-mysql=no
>Armin,
>It seems that the Interlis driver requires a newer version of Xerces than 1.7.0.
>I would suggest your upgrading to at least Xerces 2.x.  Let me know if
>that solves the problem.  I think I may need to advertise GDAL as depending
>on Xerces 2.0 or newer from now on.
>Best regards,
Yes, it worked now with Xerces 2.6.
Thanks
Armin
