[Gdal-dev] Advice on Raster Formats
    Andrey Kiselev
    dron at ak4719.spb.edu
    Tue Aug 30 14:33:01 EDT 2005
On Tue, Aug 30, 2005 at 08:03:26PM +0200, Bart van den Eijnden wrote:
> I *think* you would have to translate your tiff files first to
> compressed  tiff using the -co option.
> COMPRESS=[JPEG/LZW/PACKBITS/DEFLATE/NONE]
I just want to add that typical compression ratio in case of LZW or
DEFLATE methods may be improved by using a predictor feature. It is
disabled by default, but can by switched on with the PREDICTOR=[2/3]
parameter. Value 2 means horisontal differencing, it should help in most
cases when we are working with integer data. Value 3 corresponds to
floating point predictor and should help when you have floating point
dataset. But be carefull: predictor 3 is a newest addition from Adobe
and supported by the limited number of software (for example it is
Photoshop CS2 and software based on latest libtiff 3.7.3). Predictor 2
must be widely supported.
Interleaving type and tile/strip size affect compression ratio as well,
but not too much (though it may be valuable when you are working with
very large datasets).
Regards,
Andrey
Andrey V. Kiselev
Home phone:  +7 812 5970603  ICQ# 26871517
