[Gdal-dev] gdal_merge: output colors reverted
Maciek Sieczka
werchowyna at epf.pl
Fri Dec 9 14:15:43 EST 2005
On pią, 2005-12-09 at 14:05 -0500, Frank Warmerdam wrote:
> On 12/9/05, Maciek Sieczka <werchowyna at epf.pl> wrote:
> > Frank,
> > I have 2 tif+tfw B/W (black on white) sheets of topo map. Both are
> > something like this (they only differ very slighlty in pixel size and
> > size):
> Maciek,
> Could you try adding the -pct switch when you run
> gdal_merge.py? This should copy the colortable
> from the first image to the result image.
It helped, thanks!
Since gdalwarp and gdal_translate handle this automatically, could
gdal_merge too?
Best,
Maciek
W polskim Internecie są setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.epf.pl/
