[Gdal-dev] Re: gdal-grass-1.3.1
Luca Casagrande
luca.casagrande at gmail.com
Tue Dec 20 05:50:42 EST 2005
Alle 09:36, martedì 20 dicembre 2005, Maik Trömel ha scritto:
> Hi Luca,
> have you fixed to problem installing gdal-grass?
> Greetings Maik
> Luca Casagrande wrote:
> >Alle 17:34, martedì 13 dicembre 2005, Hernán De Angelis ha scritto:
> >>Maik,
> >>I did my installation last weekend. I did the following configure:
> >>./configure --prefix=/usr/local/gdal-grass-1.3.1
> >>--with-gdal=/usr/local/gdal/bin/gdal-config
> >>--with-grass=/usr/local/grass-6.1.0/grass-6.1.cvs
> >>and everything went smoothly. In my box, these two files were installed
> >> in:
> >>/usr/local/gdal-1.3.1/lib/gdalplugins
> >>I am not an expert but I guess that in your case something was left from
> >> a previous failed attempt to install. I think it would be a good idea to
> >> do a "make distclean" on the source directory of gdal-grass and start a
> >> new build.
> >>Good luck!
> >>Hernán
> >>El Martes 13 Diciembre 2005 15.49, Maik Trömel escribió:
> >>>I had a look on the "Makefile"
> >>>Line 49:
> >>>GLIBNAME = gdal_GRASS.so
> >>>OLIBNAME = ogr_GRASS.so
> >>>default: $(GLIBNAME) $(OLIBNAME)
> >>>install: default
> >>> install -d $(AUTOLOAD_DIR)
> >>> cp $(GLIBNAME) $(AUTOLOAD_DIR)
> >>> cp $(OLIBNAME) $(AUTOLOAD_DIR)
> >>>The error occures when trying to copy gdal_GRASS.so to $(AUTOLOAD_DIR).
> >>>I can't find gdal_GRASS.so . But why isn't it where it should be. Where
> >>>should I find this file? Is it from gdal_grass-package or from another
> >>>package? Where is it initialised?
> >>>Anybody an idea?
> >>>Greetings
> >>>Maik
> >>>Maik Trömel wrote:
> >>>>Thanks for your support,
> >>>>Line 49:
> >>>>install: default
> >>>>Where should I find this file? Is it from gdal_grass-package or from
> >>>>another package? Where is it initialised?
> >>>>Anybody an idea?
> >>>>Greetings
> >>>>Maik
> >>>>>Hamish wrote:
> >>>>>>>installing GRASS-6.0.1 from tar.gz I got a problem with
> >>>>>>>gdal-grass-1.3.1.
> >>>>>>To begin with, try the gdal-grass-1.3.1.1 version. (there was a bug
> >>>>>>in 1.3.1 release)
> >>>>>>http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz
> >>>>>I tried it: Same problem.
> >>>>>>Hamish
> >>>>>Hernán De Angelis wrote:
> >>>>>>Maik,
> >>>>>>Are your GRASS and GDAL in standard directories? If not, if you only
> >>>>>>did
> >>>>>>./configure
> >>>>>>without specifying
> >>>>>>--with-grass=/your/path/to/grass/
> >>>>>>and
> >>>>>>--with-gdal=/your/path/to/gdal/bin/gdal-config
> >>>>>I ran it this way. I think thats not the problem.
> >>>>>>it will never work. In that case you might also need to make the
> >>>>>>libraries accesible in /etc/ld.so.conf (and run "ldconfig" as root
> >>>>>>after that)
> >>>>>I have updated /etc/ld.so.conf and run ldconfig. It has no influence
> >>>>>on the problem.
> >>>>>>Hope this helps
> >>>>>>Hernán
> >>>>>>El Lunes 12 Diciembre 2005 11.13, Maik Trömel escribió:
> >>>>>>>Hello GRASS-Users,
> >>>>>>>gdal-grass-1.3.1.
> >>>>>>>I run:
> >>>>>>>./configure -> no problem
> >>>>>>>make -> no problem
> >>>>>>>make install (as root):
> >>>>>>>>install -d /usr/lib/gdalplugins
> >>>>>>>>cp gdal_GRASS.so /usr/lib/gdalplugins
> >>>>>>>>cp: cannot stat `gdal_GRASS.so': No such file or directory
> >>>>>>>>make: *** [install] Error 1
> >>>>>>>Anybody an idea what the problem could be?
> >>>>>>>Thanks for help!
> >>>>>>>Maik
> >>>>>>gdal-grass-1.3.1.
> >>>>>To begin with, try the gdal-grass-1.3.1.1 version. (there was a bug in
> >>>>>1.3.1 release)
> >>>>>Hamish
> >>>>>Maik,
> >>>>>did ./configure
> >>>>>without specifying
> >>>>>and
> >>>>>after that)
> >>>>on the problem.
> >>>>>Hope this helps
> >>>>>Hernán
> >>>>>>Hello GRASS-Users,
> >>>>>>gdal-grass-1.3.1.
> >>>>>>I run:
> >>>>>>make -> no problem
> >>>>>>Thanks for help!
> >>>>>>Maik
> >I tryed with your same configure and after a DEEP clean, but the error
> > it's the same...
> >Thx
> >Luca
Solved with manual operation...I think someone had to fix the install part of
gdal-grass-1.3.1.1
Thx for the help
Luca
"Esperienza è il nome che ciascuno da ai suoi errori. (O. Wilde) "
GENTOO-GIS Development Team
jabber: casagrande at jabber.linux.it
