[Gdal-dev] g++ links with GDAL in linux OS
Shoaib Burq hydromap at gmail.com
Tue Dec 27 07:28:42 EST 2005
I'm not sure if FWtools install the gdal shared objects and the header
files to link ur code. Just curious if you have found them where u
installed FWtools?
On 12/26/05, ³Ãô <lumiousy at yahoo.com.cn> wrote:
> Hello,everyone!
> I used to run programes with GDAL in widows OS, but now I have to deal with
> it in linux OS. They are different, and I have some problems.
> There is no supported release in slackware linux OS, is there?
> And I download the FWTools(with GDAL in it) and set up it in a Fedoral core
> system.
> I can compile my gdal demo programme, but i just cannot link and run it?
> Are there any other operations that i have to do?
> Thanks!
> __________________________________________________
> ¸Ï¿ì×¢²áÑÅ»¢³¬´óÈÝÁ¿Ãâ·ÑÓÊÏä?
> http://cn.mail.yahoo.com
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
