[Gdal-dev] L1G Landsat data
Stephan Holl
sholl at gmx.net
Thu Feb 3 02:42:04 EST 2005
Hello Frank,
On Wed, 2 Feb 2005 10:27:50 -0500 Frank Warmerdam <fwarmerdam at gmail.com>
wrote:
> On Wed, 2 Feb 2005 15:49:31 +0100, Stephan Holl <sholl at gmx.net> wrote:
> > Thanks for answering.
> > Sure, you can download the data here:
> > ftp://ftp.glcf.umiacs.umd.edu/glcf/Landsat/WRS2/p141/\
> > r055/L71141055_05520010314.ETM-USGS.LPGS/
> > (should be in one line)
> > Thanks for looking into this.
> Stephan,
> Looking in the _HDF.L1G file there does not seem to be any
> georeferencing available. I assume that is the file you are selecting
> to get the data?
Exactly.
> But the _MTL.L1G file does have various supporting metadata,
> including the product corners here:
> PRODUCT_UL_CORNER_LAT = 8.1775571
> PRODUCT_UL_CORNER_LON = 79.5875317
> PRODUCT_UR_CORNER_LAT = 8.1793694
> PRODUCT_UR_CORNER_LON = 81.7280759
> PRODUCT_LL_CORNER_LAT = 6.2812164
> PRODUCT_LL_CORNER_LON = 79.5934122
> PRODUCT_LR_CORNER_LAT = 6.2826047
> PRODUCT_LR_CORNER_LON = 81.7250438
> PRODUCT_UL_CORNER_MAPX = 344400.000
> PRODUCT_UL_CORNER_MAPY = 904200.000
> PRODUCT_UR_CORNER_MAPX = 580200.000
> PRODUCT_UR_CORNER_MAPY = 904200.000
> PRODUCT_LL_CORNER_MAPX = 344400.000
> PRODUCT_LL_CORNER_MAPY = 694500.000
> PRODUCT_LR_CORNER_MAPX = 580200.000
> PRODUCT_LR_CORNER_MAPY = 694500.000
> GROUP = PROJECTION_PARAMETERS
> REFERENCE_DATUM = "WGS84"
> REFERENCE_ELLIPSOID = "WGS84"
> GRID_CELL_SIZE_PAN = 15.000000
> GRID_CELL_SIZE_THM = 60.000000
> GRID_CELL_SIZE_REF = 30.000000
> ORIENTATION = "NUP"
> RESAMPLING_OPTION = "CC"
> MAP_PROJECTION = "UTM"
> END_GROUP = PROJECTION_PARAMETERS
> GROUP = UTM_PARAMETERS
> ZONE_NUMBER = 44
> END_GROUP = UTM_PARAMETERS
We found that too, but could not manage to use the coordinates.
Thanks for the new switch.
> So if you use the current development version of GDAL you could assign
> a coordinate system and bounds something like this:
> gdal_translate 'HDF4_SDS:UNKNOWN:"L71141055_05520010314_HDF.L1G":0'
> b10.tif -a_srs '+proj=utm +datum=WGS84 +zone=44' -a_ullr 344400 904200
> 580200 694500
> With older versions you would need to associate the bounds bounds
> after the fact with a tiff world file, since the -a_ullr flag is very
> new. If you need to handle quite a few datasets, you could write a
> script to harvest required metadata from the _MTL file. I'm sorry
> there is no full solution already implemented.
btw, are there any thought about implement a full support for this
format?
Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050203/ca6b93c8/attachment.bin
