[Gdal-dev] L1G Landsat data
Andrey Kiselev andrey.kiselev at gmail.com
Thu Feb 3 05:15:41 EST 2005
On Thu, 3 Feb 2005 08:42:04 +0100, Stephan Holl <sholl at gmx.net> wrote:
> > With older versions you would need to associate the bounds bounds
> > after the fact with a tiff world file, since the -a_ullr flag is very
> > new. If you need to handle quite a few datasets, you could write a
> > script to harvest required metadata from the _MTL file.  I'm sorry
> > there is no full solution already implemented.
> btw, are there any thought about implement a full support for this
> format?
Stephan,
I'm recommend create new Bugzilla entry with this request and assign
it to me (dron at remotesensing.org).
Best regards,
Andrey
