[Gdal-dev] what does gdal-grass provide?
Jack Varga
jvarga at boulder.net
Thu Feb 3 12:43:11 EST 2005
Markus,
Thanks, it does help. Question, does this mean QGIS can't be run
outside of Grass shell and still load Grass vector and/or raster data,
even if I compiled QGIS with the grass plugin? I seem to be able to
load Grass raster data this way, just not vector data.
Markus Neteler wrote:
>>error_routine (fatal = 1): GISRC - variable not set
> This indicates that you didn't use the plugin and probably didn't
> run QGIS within GRASS.
> Hope this helps
> Markus
