[Gdal-dev] C/C++ APIs communication
Frank Warmerdam fwarmerdam at gmail.com
Fri Feb 4 13:38:47 EST 2005
On Fri, 04 Feb 2005 15:10:04 +0100, Julien Demaria <dem at acri-st.fr> wrote:
> Hi,
> I have an OGRGeometry C++ object (created in a C++ code with the C++ OGR
> API), and I would to pass it to a C function using the C OGR API.
> This C function returns a geometry I would use in the C++ code too.
> I think it is possible because GDAL/OGR C API use internally C++ objects ?
Julien,
You are correct.  A C++ "OGRGeometry *" is the same as a C OGRGeometrH
value, except for the typecasting.  They are both really pointers to the C++
object.
Best regards,
