Dear all, With gdal_merge, it is possible to specify a nodata value (-n). It works perfectly when it is applied to a single-band dataset. But, as the nodata value is a single value, how to make it work with a RGB image? For exemple, how to specify that the "red" color is the no data value? In advance, Thank you. -Mathieu
