I used ogr2ogr (GDAL 1.2.5.0, released 2004/11/22) to translate 2d data
from Arc/Info Coverage to PostGIS database. I don't know why, but a
third coordinate appears in my PostGIS database. This should not be so
problematic since I know that the third coordinnate is not
representative. But, I have a problem when I want to map this data with
Mapserver because the request :
SELECT
asbinary(force_collection(force_2d(wkb_geometry)),'NDR'),OID::text from
habit_p_ll WHERE wkb_geometry && setSRID('BOX3D(38.5633333333333
-79.77,69.0166666666667 -56.93)'::BOX3D,
find_srid('','habit_p_ll','wkb_geometry') )
return 0 feature. The BOX3D produced has z=0.
I think that mapserver should not suppose that data are at sea level,
but I don't understand the arbitrary value of z introduced by ogr2ogr.
Greetings,
Jean-Denis
These come from orginfo on both dataset.
OGRFeature(LAB):753
ValueId (Integer) = 753
PolyId (Integer) = 0
AREA (Real) = 0.000
PERIMETER (Real) = 0.000
HABIT_P_LL# (Integer) = 753
HABIT_P_LL-ID (Integer) = 753
HABIT_P_ (Real) = 753
HABIT_P_ID (Real) = 3290
HAP_CO_PRE (String) = PRE
HAP_NO_IND (String) = 03 63 0000 001
HAP_DE_IND (String) = Lieu habité
HAP_CO_CLA (String) = SEC
HAP_CO_TOP (String) =
HAP_NM_TOP (String) = Sturgeon Falls
HAP_DA_TOP (String) = 0
HAP_CO_VER (String) = BDGA1M v1.1
HAP_DA_MOD (String) = 0
INT_AFF (String) = 2M
POINT (-79.93342590 46.36622238)
OGRFeature(habit_p_ll):753
valueid (Integer) = 753
polyid (Integer) = 0
area (Real) = 0.000
perimeter (Real) = 0.000
habit_p_ll_ (Integer) = (null)
habit_p_ll_id (Integer) = (null)
habit_p_ (Real) = 753
habit_p_id (Real) = 3290
hap_co_pre (String) = PRE
hap_no_ind (String) = 03 63 0000 001
hap_de_ind (String) = Lieu habité
hap_co_cla (String) = SEC
hap_co_top (String) =
hap_nm_top (String) = Sturgeon Falls
hap_da_top (String) = 0
hap_co_ver (String) = BDGA1M v1.1
hap_da_mod (String) = 0
int_aff (String) = 2M
POINT (-79.93342590 46.36622246 2.005)
Jean-Denis Giguère
Étudiant en géomatique
appliquée à l'environnement
Stagiaire à l'Agence de développement
de réseaux locaux de services de santé
et de services sociaux de l'Estrie
Tél. 829-3400 42008
Courriel. jdenisgiguere at fastmail.fm
