[Gdal-dev] gdal_contour
Frank Warmerdam fwarmerdam at gmail.com
Sun Feb 13 22:38:15 EST 2005
On Sun, 13 Feb 2005 18:43:04 -0600, Simpson <asimpson at i-55.com> wrote:
> repost with corrected 'Subject'...
> Greetings,
> Is there a commandline utility that will vectorize a raster and will follow
> the outside edges of the pixels, rather than the center of each pixel as
> gdal_contour does?
Drew,
I am not familiar with such a tool within or built on the GDAL library.
Are you wanting something suitable to create a polygon layer from
a classification result?  That is producing a polygon around each
connected group of pixels with exactly the same values?  Or
something like contours which generates edge vectors between
pixels at various breakpoints?
Best regards,
