[Gdal-dev] gdalinfo.exe problem
Yar
numerous at gmail.com
Thu Feb 17 18:33:21 EST 2005
Thank You Frank!
I tried running gdalinfo.exe from command line, but I get the following error:
This application failed to start because lti_dsdk_dll.dll was not found. Re-
installing the application may fix this problem.
What's in lti_dsdk_dll.dll? Can I simply obtain this dll and copy it to a
certain directory? If yes, where do I get it and where do I copy it to?
