[Gdal-dev] gdalinfo.exe problem
Chapman, Martin MChapman at sanz.com
Thu Feb 17 18:37:45 EST 2005
Copy those dll's from the srsid lib dir into the gdal/apps dir, or add
them to your path.
Martin
-----Original Message-----
Sent: Thursday, February 17, 2005 4:33 PM
To: gdal-dev at remotesensing.org
Subject: [Gdal-dev] gdalinfo.exe problem
Thank You Frank!
I tried running gdalinfo.exe from command line, but I get the following
error:
This application failed to start because lti_dsdk_dll.dll was not found.
Re- installing the application may fix this problem.
What's in lti_dsdk_dll.dll? Can I simply obtain this dll and copy it to
a
certain directory? If yes, where do I get it and where do I copy it to?
Gdal-dev mailing list
Gdal-dev at xserve.flids.com
http://xserve.flids.com/mailman/listinfo/gdal-dev
