Hi, I'm converting quite a few files from rgb to pct and I've noticed that dithering using rgb2pct is always applied, even if the files is of originally very few colours, giving a result that is worse then a conversion without dithering. I've tried to find out where the dithering is happenning, but I do not have much time to dwelve into libs
