[Gdal-dev] setting "thematic" flag for IMG
Frank Warmerdam fwarmerdam at gmail.com
Mon Jan 10 11:27:06 EST 2005
On Mon, 10 Jan 2005 11:03:23 -0500, Stephane Routelous <route at cae.com> wrote:
> Hi everybody,
> I'm reading a thematic img image and I'm modifying some pixels.
> The problem is that when I write back the modified file, the layerType is
> set as "athematic".
> Is there a way to force the written image to be "thematic" and not
> "athematic" ?
Stephane,
Currently the layerType is set to athematic by default, and only reset to
thematic if you write a pseudocolor table to the band.  It wouldn't be
hard to add access to the layerType for getting and setting via metadata
if you need to be able to set it.
I should be able to implement it today or tomorrow if you decide you
need the ability.
Best regards,
