[Gdal-dev] setting "thematic" flag for IMG
Stephane Routelous route at cae.com
Mon Jan 10 11:31:58 EST 2005
Hi Frank,
thanks a lot for your answer.
If it is not too hard for you, it will be good if I can get access to the
metadata setting quite quickly (today or tomorrow seems very good).
If you don't have time, I can try to dig into the code to make it, but I
never touched or used the metadata mecanism.
Thanks again for your quick answer.
Best Regards,
Stephane Routelous
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
Sent: Monday, January 10, 2005 11:27 AM
To: Stephane Routelous
Cc: 'Gdal-Dev (E-mail); Mohamed Wali-Alami
Subject: Re: [Gdal-dev] setting "thematic" flag for IMG
On Mon, 10 Jan 2005 11:03:23 -0500, Stephane Routelous <route at cae.com>
wrote:
> Hi everybody,
> I'm reading a thematic img image and I'm modifying some pixels.
> The problem is that when I write back the modified file, the layerType is
> set as "athematic".
> Is there a way to force the written image to be "thematic" and not
> "athematic" ?
Stephane,
Currently the layerType is set to athematic by default, and only reset to
thematic if you write a pseudocolor table to the band.  It wouldn't be
hard to add access to the layerType for getting and setting via metadata
if you need to be able to set it.
I should be able to implement it today or tomorrow if you decide you
need the ability.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
