[Gdal-dev] ecw support under linux
Jack Varga jvarga at boulder.net
Sat Jan 15 22:47:44 EST 2005
Martin, et al,
I just checked and its still not listed
(http://www.ermapper.com/downloads/default.aspx#16).  I was told I would
be notified when it was ready.  Their most recent press release on the
subject says December 2004 but I know how that goes.  It's interesting
you say they develop on linux and then port.  Same as PCRaster, and
that's not available from a link on their site either (I had to ask for
it).
-jv
Chapman, Martin wrote:
> I called ERMapper about this issue in August and they said it's now available on their download site.  They said their technology is built on Linux and then ported to Windows for release, but it's not supported on Linux...go figure that one.  Anyway, I never verified if this was true so you would have to download it and try it out.  If you get it done let me know.
> Thanks,
> Martin
> 	-----Original Message-----
> 	From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
> 	Sent: Sat 1/15/2005 8:00 PM
> 	To: Piero Cavalieri
> 	Cc: gdal list
> 	Subject: Re: [Gdal-dev] ecw support under linux
> 	On Sun, 16 Jan 2005 04:35:35 +0100, Piero Cavalieri
> 	<pierocavalieri at tiscali.it> wrote:
> 	> In ERMapper site, I didn't find linux packages.
> 	> Is there a way to have .ecw support via gdal, under linux ?
> 	Piero,
> 	It is not possible to get ECW support on linux at this time; however, my
> 	undestanding is that a source release of the ECW SDK is coming out
> 	soon and when that happens we should have little trouble porting it to
> 	Linux and using it with GDAL.
> 	Best regards,
> 	I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> 	light and sound - activate the windows | http://pobox.com/~warmerdam
> 	and watch the world go round - Rush    | Geospatial Programmer for Rent
> 	_______________________________________________
> 	Gdal-dev mailing list
> 	Gdal-dev at xserve.flids.com
> 	http://xserve.flids.com/mailman/listinfo/gdal-dev
