[Gdal-dev] color table problems
Mario Beauchamp
starged at videotron.ca
Fri Jan 21 22:39:50 EST 2005
Hi Frank,
On Fri, 21 Jan 2005 16:24:59 -0500, Frank Warmerdam <fwarmerdam at gmail.com> wrote:
>> def getColorTable(f):
>> band = gdal.Open(f).GetRasterBand(1)
>The problem turns out to be related to reference counting.
>It turns out that "band" objects don't get a reference to the
>dataset the way I bound GDAL in Python. So you need to be
>careful to keep around a reference to the dataset till you are
>done operating on the file.
>eg.
> ds= gdal.Open(f)
> band = ds.GetRasterBand(1)
> ... do stuff ...
> ds = None
Thanks. This could explain a lot, since I often use "shortcuts" such as these...
Are there other objects that don't get a reference?
I also often wondered about how to properly close a dataset and make sure everything gets written to
the file before closing. Is that the purpose of the FlushCache() method?
Thanks again.
Mario B.
Landsat images (demo):
http://pages.infinit.net/starged/landsat/home.htm
