[Gdal-dev] color table problems
Frank Warmerdam
fwarmerdam at gmail.com
Fri Jan 21 16:24:59 EST 2005
On Wed, 19 Jan 2005 18:08:10 -0500, Mario Beauchamp
<starged at videotron.ca> wrote:
> Hi all,
> I'm trying to assign a ColorTable to a VRT in OpenEV using vrtutils.VRTDatasetConstructor(). The
> AddSimpleBand method needs "ColorInterp" and "colortable" so to get it from the source file, I have:
> def getColorTable(f):
> band = gdal.Open(f).GetRasterBand(1)
Mario,
The problem turns out to be related to reference counting.
It turns out that "band" objects don't get a reference to the
dataset the way I bound GDAL in Python. So you need to be
careful to keep around a reference to the dataset till you are
done operating on the file.
eg.
ds= gdal.Open(f)
band = ds.GetRasterBand(1)
... do stuff ...
ds = None
At the point there are no references to a GDAL dataset it gets
closed. Operating on objects from a closed dataset results in
disaster sooner or later.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
