[Gdal-dev] GML and GDAL
Chapman, Martin MChapman at sanz.com
Wed Jan 26 21:33:36 EST 2005
Bruce,
I'm not sure this applies to your situation, but I would look at the OGC WFS (web feature service).  Basically, it is an http based protocol for querying feature info and geometry.  Because it's a standard, most new products have built in support for it, or they have free plugins available.
Martin
	-----Original Message-----
	Sent: Wed 1/26/2005 9:03 AM
	To: gdal-dev at xserve.flids.com
	Cc:
	Subject: FW: [Gdal-dev] GML and GDAL
	Frank: sorry for the previous direct mail.  I hit reply and didn't pay
	attention to where it was going.
	Frank and Norman:
	  Thanks for your replies.
	I'll give a little background and maybe from that you can tell if I am
	going the wrong direction.
	I have been working with the Blue Marble Viewer and am in the process of
	building a similar tool as that allows us to use the Blue Marble data
	sets or basic DEM / images files to provide accurate 3D scenes.  I
	currently use GDAL / OGR to let the user overlay ArcView shape files on
	the scene and through Demeter to load terrain files.
	The original Blue Marble Viewer developer is animate that the GUI should
	not be part of the visualization tool because it would slow things down
	too much.  The new tool already has a DIS (IEEE 1278) interface to allow
	it to be used in interactive simulations but I need to give the user
	better local control of the scene to do things like overlay processed
	image data over the scene and measure various aspect within the scene.
	My thought was to use XML (since everyone is soooo crazy about it these
	days) messages either through a local pipe or a network socket as a
	control mechanism.  Since GML is a defined standard I was thinking of
	using that.  I have not had time to go through the 600 GML page document
	(though I am in the process of doing so) to see if it can be used this
	way.
	Is there a better standard protocol for doing such thing that will allow
	the GIS tools to pass control and data messages or can GML be used that
	way?
	Thanks again.
	Bruce
	From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
	Sent: Wednesday, January 26, 2005 9:53 AM
	To: Clay, Bruce
	Cc: gdal-dev at xserve.flids.com
	Subject: Re: [Gdal-dev] GML and GDAL
	On Wed, 26 Jan 2005 09:39:12 -0500, Clay, Bruce <bclay at ball.com> wrote:
	> Sorry if these questions are off track but it seems that the GDAL user
	group
	> if probably the most competent group to ask these questions.
	> Can anyone describe in laymen's terms how the Geography Markup
	Language
	> (GML) would be used between a 3D terrain visualization tool and
	external
	> users?
	Bruce,
	I can imagine a few ways, but your question seems a bit peculiar.  GML
	would be a reasonable format to provide view position, DEM and feature
	overlay data to a 3D terrain visualization tool but of course the end
	user
	isn't going to be entering GML directly.
	> Does GDAL have any support for GML?
	There is an OGR driver for reading and writing GML data. It has a
	variety of limitations but works reasonably well for simple GML
	datasets.
	Note that OGR is a feature interface.  So it is used to read GML files
	full
	of point, line, and polygon features.  Not raster DEMs.
	> Is there any particular reason to use or not use GML to control a GUI
	less
	> visualization tool from an external GUI?
	GML is a geographic data encoding format.  It could be used as an input
	format to a visualization service but in general I would not imagine it
	being used the way you suggest.   Of course, I am not sure what
	sort of decoupling your are trying to establish between the GUI and the
	backend.
	Best regards,
	I set the clouds in motion - turn up   | Frank Warmerdam,
	warmerdam at pobox.com
	Gdal-dev mailing list
	Gdal-dev at xserve.flids.com
	http://xserve.flids.com/mailman/listinfo/gdal-dev
