[Gdal-dev] OGR GML output
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Wed Jan 26 21:52:55 EST 2005
Using under GDAL 1.2.5, I converted a shapefile to a GML document, i.e.:
ogr2ogr -f GML out.gml hydroshedg.shp
...and have some comments / suggestions w.r.t. the output GML:
.xsd file generated:
- http://schemas.cubewerx.com/schemas/gml/2.1.2/feature.xsd is used as
the schemaLocation for the GML import. Suggest changing to
http://schemas.opengeospatial.net/gml/2.1.2/feature.xsd
- the ogr namespace in the .xsd and the .gml document differ. Should be
the same (suggest http://gdal.maptools.org/ogr/)
.gml file generated:
- the root element should add an attribute which points to the .xsd file
generated (i.e. xsi:schemaLocation="http://gdal.maptools.org/ogr/
./out.xsd"
- suggest a default namespace in the root element (i.e.
xmlns="http://gdal.maptools.org/ogr/"), thus negating the requirement to
prefix elements with "ogr".
I'd be willing to help out with this in terms of testing and XML /
Schema design.
Cheers
..Tom
