[Gdal-dev] how to uninstall gdal
Frank Warmerdam
fwarmerdam at gmail.com
Fri Jul 8 17:21:48 EDT 2005
On 7/8/05, Xiaodong Zhang <zhang at aero.und.edu> wrote:
> Hi developers,
> With all the love to gdal and high regards to the developers, I'm just
> curious to know how to uninstall gdal package once it is installed
> through ./configure, make, make install (as root). I'm not sure if I
> will ever need it, but it would be nice to know if this can be done or
> not. I tried "make uninstall", which did not work.
> For the proj package, "make uninstall" seems working.
> Appreciate if someone can drop a line or two. Thanks.
Xiadong,
Sorry, make uninstall is not currently a feature of GDAL.
If you need to be able to remove it, you could install it into
a GDAL specific tree with a configuration something like:
./configure --prefix=/usr/local/gdal
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
