[Gdal-dev] nodata error with gdalwarp and -rcs option
Matt Wilkie
matt.wilkie at gov.yk.ca
Tue Jul 12 16:01:22 EDT 2005
vincent at ecovla.nl wrote:
> Frank, folks,
> I found an error with gdalwarp. It appears that when the -rcs resampling
> option is used in combination with -srcnodata and -dstnodata, the nodata
> pixels still get interpolated. When another resampling option is used,
> the nodata pixels are (correctly) retained as such in the output image.
this sounds the same as
http://bugzilla.remotesensing.org/show_bug.cgi?id=793
as long as my resampling is set to default (bilinear) nodata remains nodata.
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
