[Gdal-dev] nodata error with gdalwarp and -rcs option
vincent at ecovla.nl
Wed Jul 13 03:34:25 EDT 2005
Matt Wilkie wrote:
> vincent at ecovla.nl wrote:
>> Frank, folks,
>> I found an error with gdalwarp. It appears that when the -rcs resampling
>> option is used in combination with -srcnodata and -dstnodata, the nodata
>> pixels still get interpolated. When another resampling option is used,
>> the nodata pixels are (correctly) retained as such in the output image.
> this sounds the same as
> http://bugzilla.remotesensing.org/show_bug.cgi?id=793
> as long as my resampling is set to default (bilinear) nodata remains
> nodata.
You're right, I should have searched bugzilla first of course...
Apologies for the spam.
Vincent.
