[Gdal-dev] problems compiling dods into gdal
Charlton Purvis
cplist at earthlink.net
Mon Jul 18 14:50:25 EDT 2005
Thanks, Frank. Everything works like a charm. I really appreciate your help and quick fix.
Charlton
-----Original Message-----
Sent: Jul 18, 2005 9:15 AM
To: warmerdam at pobox.com
Cc: gdal-dev <gdal-dev at xserve.flids.com>
Subject: Re: [Gdal-dev] problems compiling dods into gdal
Thanks, Frank:
I registered the bug -- you're so darn fast I couldn't tell whether or not you took care of the INC issue. But I included it there, nevertheless.
Many, many thanks!
Charlton
Sent: Jul 15, 2005 1:20 PM
To: Charlton Purvis <cplist at earthlink.net>
On 7/15/05, Charlton Purvis <cplist at earthlink.net> wrote:
> Hi, all:
> I am running into problems when I try building OPeNDAP into gdal. I was originally trying to follow a MapServer wiki post (http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?DODS_Build), but that was a bit dated, so I thought I'd get the latest and greatest of both worlds.
> I believe I successfully covered my bases w/ the prerequisite libcurl and libxml.
> I downloaded libdap-3.5.1.tar.gz from UCAR and followed a:
> * ./configure --prefix=/usr/local/dods/3.5.1
> * make
> * make install
> * ldconfig
> That all went fine.
> I downloaded gdal-1.2.6.tar.gz from gdal.org and followed a:
> * ./configure --with-dods-root=/usr/local/dods/3.5.1 --without-python
> * The configure works fine and shows that DODS support will be 'yes'.
> * make
> * Make has problems when it gets to the dods stuff. It can't find .h's, and it looks like the INC gets set incorrectly. It should be looking in /usr/local/dods/3.5.1/include/dap rather than what I see on the @INC output which is /usr/local/dods/3.5.1/include.
Charlton,
I have committed changes to GDAL in CVS to put both dods_root/include
and dods_root/include/dap into the include path. I think pushing
stuff down into
a dap subdirectory must be a new convention.
> make -C dods install-obj
> make[2]: Entering directory `/usr/local/download/gdal-1.2.6/frmts/dods'
> /bin/sh ../../libtool --mode=compile g++ -Wall -O2 -I../../port -I../../gcore -I../../alg -I../../ogr -I../../ogr/ogrsf_frmts -I../../port -I/usr/local/dods/3.5.1/include -c -o ../o/dodsdataset2.o dodsdataset2.cpp
> g++ -Wall -O2 -I../../port -I../../gcore -I../../alg -I../../ogr -I../../ogr/ogrsf_frmts -I../../port -I/usr/local/dods/3.5.1/include -c dodsdataset2.cpp -fPIC -DPIC -o ../o/.libs/dodsdataset2.o
> dodsdataset2.cpp:50:19: debug.h: No such file or directory
> [followed by more errors]
> So I thought that it was only a matter of an @INC path. Since I had nothing to lose I tried both adding the correct path to the INC of the ./configure, and then I also tried copying the *.h's into what gdal wanted for the heck of it. Neither worked well since I ran into cpp errors which I know zilch about.
> (after copying the *.h's to where gdal could find them)
> dodsdataset2.cpp: In constructor `DODSDataset::DODSDataset()':
> dodsdataset2.cpp:300: error: no matching function for call to `DDS::DDS()'
> /usr/local/dods/3.5.1/include/DDS.h:254: error: candidates are: DDS::DDS(const
> DDS&)
This may be a bit harder. I'll try and prepare a dap 3.5.1 build and see
what I can figure out.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
