[Gdal-dev] reading hdf4 file
Frank Warmerdam
fwarmerdam at gmail.com
Mon Jul 25 19:14:39 EDT 2005
On 7/25/05, Sabine Grabner <csab7771 at uibk.ac.at> wrote:
> hello,
> i try to read a hdf4 file but poDataset->GetRasterCount() returns 0 bands even
> though gdalinfo lists all bands of the file.
> i work with GDAL 1.2.6.0 from 03/13/2005.
> can anybody help out please?
Sabine,
It would be helpful to show the gdalinfo report. Most likely the gdalinfo
report is listing a set of subdatasets but not any bands. Generally for
HDF you need to open the file, get a list of subdatasets (from metadata)
and then open one or more of those subdatasets in order to get the
accesss to the imagery.
The following code from gdal_translate might give an idea how to get
the list of subdatasets, and use it.
/* Handle subdatasets. */
if( CSLCount(GDALGetMetadata( hDataset, "SUBDATASETS" )) > 0 )
if( !bCopySubDatasets )
fprintf( stderr,
"Input file contains subdatasets. Please, select
one of them for reading.\n" );
else
char **papszSubdatasets = GDALGetMetadata(hDataset,"SUBDATASETS");
char *pszSubDest = (char *) CPLMalloc(strlen(pszDest)+32);
int i;
int bOldSubCall = bSubCall;
argv[iDstFileArg] = pszSubDest;
bSubCall = TRUE;
for( i = 0; papszSubdatasets[i] != NULL; i += 2 )
argv[iSrcFileArg] = strstr(papszSubdatasets[i],"=")+1;
sprintf( pszSubDest, "%s%d", pszDest, i/2 + 1 );
if( ProxyMain( argc, argv ) != 0 )
break;
bSubCall = bOldSubCall;
CPLFree( pszSubDest );
GDALClose( hDataset );
if( !bSubCall )
GDALDumpOpenDatasets( stderr );
GDALDestroyDriverManager();
return 1;
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
