[Gdal-dev] RE: PostGIS Driver Performance
Craig Miller craig.miller at spatialminds.com
Thu Jul 28 11:39:55 EDT 2005
In case it's useful, here is the SQL I used to do this when I was working on
a PostGIS OLEDB provider proof of concept last fall.
        char * SQL_SELECT_TABLES = "SELECT a.relname AS
Name,obj_description(oid, 'pg_class') AS Description FROM pg_class a,
pg_user b WHERE ( relkind = 'r') and relname !~ '^pg_' AND relname !~
'^sql_' AND relname !~ '^xin[vx][0-9]+' AND b.usesysid = a.relowner AND NOT
(EXISTS (SELECT viewname FROM pg_views WHERE viewname=a.relname))";
--Craig
-----Original Message-----
Sent: Thursday, July 28, 2005 5:48 AM
To: Craig Miller; gdal-dev
Subject: PostGIS Driver Performance
Hi Craig!
Why the PostgreSQL driver loads all non-system tables from the database
as layers? When we have a lot of tables this results in too big
overhead. When we are working with PostGIS all layers are listed in the
geometry_columns table and we can use it to prepare a list of tables to
load. I can modify the driver to load only layers from the
geometry_columns table when we have PostGIS and fallback to the old
behaviour when we have plain PostgreSQL.
Oleg.
