[Gdal-dev] convert a group of points (lat, lon) to a shape file
Pericles S. Nacionales
nacional at cbs.umn.edu
Wed Jun 22 16:53:58 EDT 2005
Greetings, Xiaodong!
I'm sure there are more than one way to do it but in the past this is
what I've done (this is the ESRI generate file format):
101
lon1,lat1
lon2, lat2
lonN,latN
END
102
lon1,lat1
lon2, lat2
lonN,latN
END
END
save it as a file and you can then find the gen2shp utility somewhere
(or the gen2shp extension for ArcView3) and convert it to a shapefile.
Or you can use Arc/Info "generate" to create a coverage. The example
above will give you two polygons with IDs 101 and 102. I haven't done
this in years so my memory might be a little hazy.
If ogr2ogr supports it, that would be even better!
I hope that helps.
-Perry
Xiaodong Zhang wrote:
> Hi,
> I have a humble question which may have been answered before, but could
> anybody please kindly help out. The question is:
> If I have a series of points, say in a text file, like
> lat1, lon1
> lat2, lon2
> lat3, lon3
> lat4, lon4
> How should I format the text file such that an ogr utility (e.g.,
> ogr2ogr) can convert it into a shapefile as a polygon.
> Many thanks
> Xiaodong
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
