[Gdal-dev] convert a group of points (lat, lon) to a shape file
Xiaodong Zhang
zhang at aero.und.edu
Thu Jun 23 11:12:26 EDT 2005
Thanks Perry,
Your memory is good. It is working. Much appreciate.
Xiaodong
Pericles S. Nacionales wrote:
> Greetings, Xiaodong!
> I'm sure there are more than one way to do it but in the past this is
> what I've done (this is the ESRI generate file format):
> 101
> lon1,lat1
> lon2, lat2
> lonN,latN
> END
> 102
> lon1,lat1
> lon2, lat2
> lonN,latN
> END
> END
> save it as a file and you can then find the gen2shp utility somewhere
> (or the gen2shp extension for ArcView3) and convert it to a shapefile.
> Or you can use Arc/Info "generate" to create a coverage. The example
> above will give you two polygons with IDs 101 and 102. I haven't done
> this in years so my memory might be a little hazy.
> If ogr2ogr supports it, that would be even better!
> I hope that helps.
> -Perry
> Xiaodong Zhang wrote:
>> Hi,
>> I have a humble question which may have been answered before, but
>> could anybody please kindly help out. The question is:
>> If I have a series of points, say in a text file, like
>> lat1, lon1
>> lat2, lon2
>> lat3, lon3
>> lat4, lon4
>> How should I format the text file such that an ogr utility (e.g.,
>> ogr2ogr) can convert it into a shapefile as a polygon.
>> Many thanks
>> Xiaodong
>> Gdal-dev mailing list
>> Gdal-dev at xserve.flids.com
>> http://xserve.flids.com/mailman/listinfo/gdal-dev
