[Gdal-dev] clipping raster using polygon?
Reinaldo Escada Chohfi
rec at geodesign.com.br
Thu Jun 23 18:51:16 EDT 2005
Bart,
You can do this operation using the freely distributed gis/rs software
called SPRING, which is available from INPE-Brasil. The SPRING link is
http://www.dpi.inpe.br/spring/index.html
You can load GeoTiff, Tiff w/ TFW, etc and shapefiles to SPRING. There is
a tool to do this under the Tools Menu. Also, INPE has developed an open
source GIS classes and functions library called Terralib that may have the
tool available. The link to Terralib is http://www.terralib.org/
Hope it helps. Reinaldo
At 06:35 PM 6/23/2005, you wrote:
>Quoting Bart van den Eijnden <BEN at Syncera-ITSolutions.NL>:
>>Hi list,
>>is it possible using GDAL to clip a raster using a polygon from eg a
>>shapefile and have all the rest turn into NODATA values? If it is
>>possible, how does it work?
>>Thanks in advance.
>>Best regards,
>>Bart
>Bart,
>I don't know if there is a programaticaly way of doing it with gdal.
>However, you can do it with my "Mirone" program.
>Mirone doesn't know about shape files, but you can import simple ascii
>files. If they are closed you are ofered the possibility to "Crop grid"
>and to specify the outside polygon value (the NodataValue)
>See
>w3.ualg.pt/~jluis/mirone
>but try instead (if you want, off course) the more updated versions at
>ftp.ualg.pt/users/jluis/m_gmt/tmp
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at xserve.flids.com
>http://xserve.flids.com/mailman/listinfo/gdal-dev
Reinaldo Escada Chohfi, Ph.D.
Diretor
GeoDesign Internacional
www.geodesign.com.br
E-mail: rec at geodesign.com.br
Tel./Fax: 0-XX-12-3153-5115 (Local)
55-12-3153-5115 (Intl.)
Inteligência e Tecnologia Espacial de Ponta
Urbanismo, Estudos Ambientais, Monitoriamento Ambiental,
Geoprocessamento, GIS, Processamento de Imagens Geográficas,
Sensoriamento Remoto: Imagens de Satélites
Compressão de Imagens e Documentos Escanerizados
Servidor de Conteúdo - Integração de Sistemas
Revendedor Autorizado da LizardTech no Brasil
Vila Peralta, 42
12607-040 - Lorena - SP - Brasil
Informação confidencial. Não retransmitir sem autorização.
Copyright (c) 2005 GeoDesign Internacional
Todos os direitos reservados.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050623/fdc93508/attachment.html
