[Gdal-dev] clipping raster using polygon?
jluis at ualg.pt
jluis at ualg.pt
Thu Jun 23 19:20:30 EDT 2005
Quoting Bart van den Eijnden <BEN at Syncera-ITSolutions.NL>:
> Hi list,
> is it possible using GDAL to clip a raster using a polygon from eg a
> shapefile and have all the rest turn into NODATA values? If it is
> possible, how does it work?
> Thanks in advance.
Bart,
Another option.
A non GIS, very functional (just load the grid and precess it model)
w3.ualg.pt/~jluis/mirone
(but you better use the versions at ftp.ualg.pt/users/jluis/m_gmt/tmp)
Example:
"Draw-> import line" // import you polygon lline (ascii)
right click on the line and select "ROI crop grid"
