[Gdal-dev] Will GDAL do other planets?
Schuyler Erle schuyler at nocat.net
Thu Jun 23 21:19:05 EDT 2005
* On 16-Jun-2005 at  3:43PM PDT, Mike Logan said:
> I haven't researched this yet - maybe this is already supported, but
>  I can think of some reasons to have GDAL load,query,reproject
>  MARS or other planetary data.    Not so much data formats (although
>  that would be nice) but rather geospecific support (radius,
> eccentricity, etc).
> Has anyone ever tackled this idea?    Or would it be
>  too much upheaval to the product?
We talk about it a little bit in Mapping Hacks -
http://mappinghacks.com/ ...  My sense is that PROJ.4 (and therefore
GDAL) will happily play along with any ellipsoid model you give it.
The only trick you may have to overcome is that longitude on Mars is
traditionally given in the range 0 to 360 degrees, versus the -180 to
180 standard here on Earth.
SDE
