[Gdal-dev] Will GDAL do other planets?
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri Jun 17 03:51:25 EDT 2005
Hamish wrote:
>>I haven't researched this yet - maybe this is already supported, but
>> I can think of some reasons to have GDAL load,query,reproject
>> MARS or other planetary data. Not so much data formats (although
>> that would be nice) but rather geospecific support (radius,
>>eccentricity, etc).
> Others have done the same using GDAL+PROJ.4 & r.in.bin in GRASS, maybe
> the old mailing list threads have some info for you. Unfortunately "Mars"
> is hard to do in the search engine.. bloody thing translates into French.
> None the less, some links to mailing list threads follow which may be
> informative. Maybe Paul remembers more?
As far as I remember everything that needed to be fixed to model Mars in
the GRASS projection system, was done.
I remember too projecting some Mars elevation data onto a spherical
globe in SG3d when I was testing the support, and it looked really well.
Not sure if I saved it though.
Paul
