[Gdal-dev] Will GDAL do other planets?
Mario Beauchamp starged at videotron.ca
Fri Jun 17 00:02:51 EDT 2005
Hi Hamish,
Hamish wrote:
> Others have done the same using GDAL+PROJ.4 & r.in.bin in GRASS,
That's pretty much the idea...
> None the less, some links to mailing list threads follow which may be
> informative. Maybe Paul remembers more?
> http://grass.itc.it/pipermail/grass5/2003-August/008536.html
> http://grass.itc.it/pipermail/grassuser/2002-November/007657.html
> http://grass.itc.it/pipermail/grassuser/1994-August/021833.html
Found some info on planetary systems here: http://pds.jpl.nasa.gov/
> MOLA data is pretty easy to import anyway:
>   http://bambi.otago.ac.nz/hamish/olympus_mons.html
Nice pix!
Mario B.
